Offline Mode Feature Request
I’m not sure if this is possible, but the ability to use my Noloco app offline would be huge. The use case would be if I am on an airplane or in a place with bad service, having the ability to access existing data and add data that would get synced later is massive.
good question @bhosey - have you tried PWAs?
According to this tutorial a Noloco PWA gives improved performance and offline access
Is that the type of thing you are looking for, or something else?
Big +1 to this, we have an opportunity with a client who will have engineers using the PWA and a huge bonus would be if they could create records when they don’t have signal which are then synced up when signal/wifi restored
