Problem on Legacy Account
I have plan dating back to 2023 which I use for a test app and some experimentation. I realize it does not support version history, so normally when I make a change that’s not working I back out of the change by using the undo arrow. I tried that today and seem to have lost everything that was on a tab on one of my pages. Is there any way it can be restored to the published version from your end? I can dm the detail if someone from support can get back to me.
If I were to transfer the app to the client business plan, would the previous versions be transferred and then be available? I’m not sure it fixes the problem, because the unpublished version is the one that shows even if I view the pwa version.
Just a little more information - after exiting completely (from all sessions whether it’s this plan or the business plan) when I come back it still shows the changed but unpublished version. On the other hand if the one other user starts the app they see the published version. That sounds good in the the version still exists, I just need to make sure I get it back.
@darragh - sorry to bother you on this, but is there any way support can look at this. I just need a one time restore to the last published version, and I know it’s a legacy account that doesn’t support this feature, but the problem happened due to the undo button and I think that should be considered a system problem.
Thanks @darragh and team, it looks good now.
