Using the ‘Rows’ layout, since the recent UI changes. If you use ‘Record Colors’, they now seem to only apply on hover on a record. They’re working fine on the ‘Table’ layout.
Having done a bit more testing, it seems to work on the first color, but if you have another color for different criteria, that one only works on hover.
Hey @nick,
Thank you for flagging this with us. I’ve reported this to our engineering team to take a look. We’ll make sure to keep you posted once we have a fix for this. Appreciate your patience in the meantime.
Hi @nick ,
The issue with the record colors not properly working when there are other criteria for the same color, and having it not have the hover animation, has now been fixed. Please feel free to test this when you get the chance. Let us know if you run into any issues. We appreciate your patience and understanding while the team worked on this
Looks great now, thanks David and team for the quick fix.
