Hey All, using the “search bar” for fields inside Visibility permission settings on individual detail sections of a Base Record page and on individual fields within those detail sections.
When searching for a field name, it won’t pull up the field if the field is an attachment (I’m wondering if it’s doing this for all array types bit I’m only looking for attachments at the moment).
Just makes sifting through 100 fields tedious
Cheers!
This Screenshot shows all the fields that show up when searching for “Super”.
This is the field I needed, an attachment, with the name Super in it, but I found manually
I don’t think this is related to the type of field actually, and more likely to do with that field being renamed at some point and how we “Search”
It likely doesn’t work the exact way you would expect, unfortunately
Hello
I have the same issue, but it works for me when using the browser search and not the noloco builder search (at least on Chrome, it’s more buggy on Firefox).
Click on the search field of the noloco builder first to expand all fields, and then browser search it :
All good! I didn’t even know it existed for a full year so 99% of the time it works and speeds things up. A minor thing if anything at all
@Jean-David thanks so much for sharing what worked for you! I’ll try that next time!
