Simple website with Noloco data?
Hi,
I currently use Webflow and love how simple it is to design pages but it is overkill for what I need when Noloco is managing the content that I want to display.
I would love to hear your suggestions for simpler/cheaper alternatives to Webflow.
Will.
Hello @WillB,
First of all, you need to understand what your use case is.
  1. Public Website with all Design, Integration and SEO support
  2. Do you need to use more inbuilt tools OR define every component from scratch?
Website builder from scratch: Webflow, Bubble, and Wix.
Using these tools you can achieve 1) & 2) but there are need for more in-depth knowledge of these tools as well.
  1. If you need to use your website as an admin panel or for your customer/client access.
In that case you can use these different portal builders like Noloco
The most important thing is first to define your requirements then research or use a consultant to understand what tools ( or sets of tools) fit these requirements.
Then go ahead.
:+1:
