Toggle to collapse detail elements
What
  • The ability to toggle a detail element so that it collapses all the fields under it, leaving only the grey header area (with any action buttons) visible to the user.
  • The default state (collapsed vs expanded) can be defined by the builder in the detail element’s settings
  • The setting would be “sticky” (ideally), which means that Noloco would remember how you last left that section.
Why
  • This is more of a quality-of-life ask. A general UI improvement.
  • Lots of people stuff detail elements with many fields, so being able to make the layouts more visually bearable through collapsed sections (if desired) would be fantastic.
Exhibit
I was about to post this but figured I should check if someone else already had.
This feature does exist now:
Right, the more important part of the request relates to its behavior:
