Tooltips and / or action buttons for Highlight fields
We are starting to use colored highlight fields as status fields in some dashboards.
It would be great to be able to add a tool tip that only shows up when hovering over the highlight field (at the moment only helptext is available).
The cherry on the cake would be to display different tool tips - depending on the color. This way it would be possible to give the user some interactive guidance in case of problems without cluttering the screen with unnecessary helptexts.
Additionally / Alternatively it would be great to be able to use action buttons on highlight fields to be able to redirect the user where to look at i.e. to change a setting, correct a mistake etc. Of course it would be necessary to be able to provide individual actions by field (not by record view)…
