Two Factor Authentication
Minor request, but I use Authy for 2FA and upon setting that up as part of my security preferences, Authy defaults Noloco to a generic icon. Would be nice to have the real Noloco icon populate automatically, but like I said, this is mostly cosmetic.
@fullnelson this is an interesting suggestion, do you know how you end up controlling that?
Well you can manually assign/add a custom logo to any Authy token (which I’ve done) but I guess this would be a question for the Authy developer support channel to figure how to make sure one’s app logo is automatically supported. You might want to consider having a separate icon for the Community Support login vs regular Noloco 2FA logins.
I’m also trying to figure out how to just configure and use Passky login support instead of username/password, but it was not immediately clear to me so maybe post some tips on how to make that happen. I use 1Password as my password and passkeys manager so hopefully can get that working as needed.
I’d like to add a request to enable 2FA/MFA for all users as part of the Pro plan. Most of my users will be external, so enabling 2FA as part of SSO (enterprise plan) won’t necessarily solve the issue.
I know that’s an older thread, but I was wondering if 2FA for any user account from a paid plan is on the roadmap. This is an essential feature for any company to protect their data, and it’s seen as a standard for any SaaS platform.
Hey @Christoph @laurak and @fullnelson ! Resurfacing this thread the let you all know that Two Factor Authentication is now available for everyone on our Business and Enterprise plan
Read more about setting it up here:
If you need to reactivate your account, or talk to sales about upgrading, you can let our support team know and they can help you out.
Thanks
Hi @darragh, do you know if enabling 2FA would prompt the end user for a code every time they login or could it be set to trigger only on new devices/locations like O365?
Thanks
Great question @garyGHL - for now it’s every time they login (which is only when their sessions expire)
Thanks Darragh, I may defer this for a bit, we have another financial app that asks on each login and its upsetting them all :sweat_smile:
Not quite sure how Microsoft do theirs but its only on a new device or location (IP), assume it must be conditional access & trusted devices.
Thanks anyway.
