Using Grid View + Tabs for extra details
I’m trying to put a Grid view (takes up the entire width of the page without white space) instead of the Table view for a collection. I also need to have Tabs for separate pages on that same area though, and am not having any luck.
Can Grid view not be used on a collection when it’s on a different page than the initial page that AI builds when you first add a section?
e.g. Can Grid View not be used if the collection is not a base record page or a blank page?
Alternatively, can Tabs only be added to Base record pages or blank pages?
Neither are visible (add tabs) or (change layout to grid) to what I can see so far. thanks all!
Hey @dianakirby,
Hey @dianakirby,
As you guessed, the Grid layout is only available in page table views, not in list components on blank pages. Tabs aren’t supported in table views either. To get a similar result, you could maybe set the list component width to Full to use as much of the page width available. Would that work for you?
Thanks Carlos! All good- we figured it out for their existing needs.
Thank you!
