Hi, I have a workflow that’s set to run when a specific field is updated, but it’s not triggering when that field is updated.
I’m using a Noloco form (action button with module) to update that field and I’m using an Airtable base. The only time that the automation triggers is the first time that the field is updated, not any subsequent times.
Any suggestions would be appreciated, thanks!
