When i publish the zap, it workes fine and passes but i cant do the test, and if i cant do the test from the last zap, i cannot collect the data for the second step in zapier.
Also i tried a workaround, i put another ID on the last search step and collected the data, then changed back to the real ID, but when i run it live its not working i got the same error
I think the problem is that our Zapier integration needs to load all of the linked data too, which in your case, that user has >1000 tilldela-utforare linked records…
