I’m curious to know if anyone has moved their data from Airtable to Noloco Tables if so, did you see improvements in performance? I have a simple CRM that lives in Airtable. It works fine but data entry feels a little sluggish. I’m considering moving the data into Nolocos tables if it will improve performance. Thanks!
Hi @bhosey ![]()
How many records do you have in your base at the moment? As a general rule that more records you have the more marked the performance improvement you’ll see
That being said though, having everything on the same servers should result in performance improvements regardless
