I want advice on how to make my first Noloco application
Hey everyone,
I want create my first app and have begun researching Noloco but I am still learning the ropes. I have mastered some of the fundamentals but I am having trouble effectively integrating data and setting up automations.
I want to hear from others who have been using Noloco for a while. What resources helped you get started? Anyone have Any tips for handling more complex workflows or integrating with third party tools?? Also I have seen some tutorials but I want examples and personal experiences.
Also, I was wondering if anyone has used the splunk tool in conjunction with Noloco for data analytics or monitoring??
Also i have check this Problem with airtable sync tonight with one noloco application I want to hear if it helped streamline your processes.
Thanks in advance :slight_smile:
I’ve never used splunk but am now looking into it - I set up noloco with data sources from Airtable, MySQL, and then Noloco tables - what i found is Airtable isn’t dynamic enough to handle a lot of what I needed so SQL and Noloco tables seem to be the best for complex data.
if you’re not already committed to a specific spot to store your data Noloco Tables perform the best - but having your data mapped out prior to creating the tables makes a big difference when it comes to speed
