Changing linked fields creates error you can not fix
By changing noloco linked fields you get an error that you can not fix.
Way to issue
set up a linked field
Add data
Change or edit field
Error that will not allow you to recreate or dele the field.
Thanks for sharing @Kieran - would you be able to share the URL to that page? We’ll fix this for you and make sure to fix the underlying issue
Sorry Darragh, I rolled back to a previous backup but I will share the link in case you can find something from the logs https://membership.noloco.co/
