Drag and drop bulk-selected records
In a collection, you can enable “bulk actions.” However, after selecting multiple records, you cannot drag and drop them to another grouping (if grouping is enabled). Instead, it only drags the current/individual record your mouse clicked on and began dragging from.
This would be so helpful for quick data management. For example, if your collection was grouped by Status, you wouldn’t need a dedicated “Status” action button to update those records in bulk. Instead, you just select the desired records, then drag them into the grouping you want – simpler configuration (as opposed to an action button), and more intuitive for users.
