Field-Level Authentication (e.g., PIN or Memorable Word Prompt for Sensitive Fields)
Description:
I’d like to request a feature that allows true field-level authentication in Noloco. Specifically, I want the ability to require users to enter a PIN, password, or selected characters from a memorable word before they can view or edit certain sensitive fields in a record—even after they’re logged in.
Use Case:
When opening a customer record, before showing contact information or sensitive details, prompt the user to enter 2 characters from the customer’s memorable word (or a PIN/password).
This would help us comply with security best practices and industry regulations for handling customer data.
It would also allow us to add an extra layer of protection for highly sensitive information, even for authenticated users.
Why it matters:
Role-based permissions are great, but sometimes we need an extra layer of security for specific fields.
Field-level authentication is common in financial, healthcare, and security-focused apps.
This would make Noloco even more suitable for sensitive business use cases.
