Inline edit field for collections, grids, etc is buggy
The pop out box for inline editing within a collection, rows or grids (its probably on other views/modules as well but these are the ones I use) is quite buggy. It often closes itself while typing and is, in general, not user friendly compared to the direct inline editing that’s in a details section. I’m sure there are applications where this is necessary such as when the text box area exceeds the field size on the page. Ideally it would be set up similar to airtable where you have the option to expand to a pop out box.
Screenshot 2024-03-19 at 1.20.50 PM
But, at the very least, could we get this more reliable. I’m using inline editing a lot and often have to click into the pop up box several times before I can update my info accurately.
https://drive.google.com/file/d/1k–swsYyBTvgW_Nyj1eA6lv5dL-PDu1R/view?usp=sharing
Here’s a video of the edit modal closing itself while I’m typing, this is pretty common.
The inline edit feature on collections such as tables remains unreliable, its a regular headache for my users and I. It forces us to click into each record and use the details in line editing for a more reliable experience, although that has also had some glitchiness lately with the cursor jumping boxes occassionally.
Inline edit glitch
This is almost unbearable. It’s been a good half year of this, we really need a solve. My client uses this functionality a lot and entering data is a nightmare.
Bumping this as it really needs a resolution, inline editing on tables is often a necessity but the UX of it at the moment is terrible when you’re making lots of quick changes. It seems to be linked to Noloco updating the data in the background, if you wait for the “Updating” pop-up at the bottom of the screen to disappear before you click onto the next cell then there are no issues with the edit box closing, otherwise if you click into one during the “Updating” when that pop-up disappears is also when the edit box closes.
We hear you all, unfortunately this isn’t a quick win on our side and instead will be part of a larger improvement we hope to implement soon in Q1 2025
