Today is the first day of our first-ever Launch Week. Each day this week we will be announcing some major new features available in Noloco.
Today’s theme is Noloco Build Mode 2.0.
We are thrilled to announce the launch of our most significant update to the Noloco App Builder since its inception in July 2022. After two years of continuous innovation and adding incredible features, we’ve redesigned our build mode from the ground up. This update is not just a facelift; it’s a complete restructuring designed to accommodate the wealth of new features we’ve introduced, ensuring they’re easily accessible and intuitively organized.
Dedicated Pages Editor:
We’ve separated the Pages editor from the Navigation Bar to streamline your design process. This dedicated space allows for more focused page creation and management, making it simpler to bring your app’s structure to life.
Revamped Customization Panel:
Say goodbye to the right-side customization clutter. Our new Customization Panel is now relocated, offering a cleaner, more organized workspace for your app design tasks
Tabbed Panel System:
Each panel now features up to four tabs, designed to enhance your setup and customization workflow:
- General: The starting point where you define the setup for your pages or components.
- Options: Dive deeper into the configuration of your pages or components for more detailed customization.
- Fields: A specific focus on which fields are displayed on your tables, forms, or components, ensuring the right information is presented where it’s needed.
- Visibility: A dedicated tab for adjusting the visibility of your pages, components, or action buttons, giving you control over what’s seen and by whom.
Beta-Tested and Community-Approved
We understand that change can take some getting used to. That’s why we’ve spent time beta-testing these updates with a select group from our incredible community. The feedback has been overwhelmingly positive, assuring us that these changes not only make sense but significantly improve the user experience.
Designed with You in Mind
For newcomers to Noloco, this update makes features more discoverable and understandable. With guides and help text consistently placed, every element of our app builder is now logically arranged, ensuring you spend less time searching and more time creating.
We believe these updates will make a significant difference in how you interact with Noloco, enhancing both efficiency and enjoyment. As always, we’re here to support your journey and can’t wait to see the amazing apps you’ll create with these new tools at your disposal.
