I have a collection of Activities for my sales people. I created nested views for different types of activities (i.e Tasks and Goals). I am having trouble customising the new record form for each nested view. For example, I want to be able to create a new Task from the Tasks view and create a new Goal from the Goals view. Noloco has the option to select what form should be used, but I only have two options: Default and Activities. What am I doing wrong?
If you’re using nested views, then there’s only one real form (attached to the parent).
It sounds like you should be using a folder instead, then each view will have it’s own form and record page, each of which can be customized.
Got it. That makes sense. Thank you!
