Payments via Stripe?
I’m trying to set up a flow where users can pay via Stripe.
So far I’ve set up a workflow that triggers a Make webhook. In Make, a Stripe “Payment intent” is created. This is where I’m stuck. What would be the next steps in order to create a URL for users to use for payments? Or am I down the wrong path here?
Basically I just want a way to accept payments based on a collection.
Thanks!
Hey @esben
Is Zapier an option for you? How many payments are you expecting to handle per day?
thanks @domhnall. I could use Zapier if that’s better. As for payments, it’s pretty low volume for now. About 5 payment per week and probably never more than 10 per day.
@esben hi, did you find a solution? If so, how did you make it work?
No solution yet. I would think Make should be able to do this, but no luck
