When navigating back via back button or breadcrumbs, returning to the same scrolling place in the list would be very helpful. Current behavior always resets to top of list. Similar to the recent request for a similar feature when clicking into split view records.
I would like to second this feature request. Some of our customers have over 1000 records on a table and having to figure out where you left out is time consuming and frustrating for users. Short term fix: enable an option on the page settings where clicking on a record opens a new tab instead of within the same tab. While not as elegant as keeping your place on the list on the same tab, it functionally accomplishes what we are trying to do with what I would assume to be an easy coding add on.
another option I’ve found, that seems to work, is using the side panel record style
