Split View: Don't jump to top when selecting Record
I think the Split view is extremely handy for quickly peeking into different Records quickly and we use it quite a bit. However it is very irritating that whenever I click a record, The “List” scrolls up to the very top.
You basically scroll down to the the Records you want to look at, but as soon as you click one, it is being scrolled to the top. So every time i want to see the record above, I have to scroll back down and click that one. then when i want to see another one above that one - more scrolling again. And at the same time you easily loose sight of what record you are looking at because the List keeps jumping around. Not very pleasant if you’re trying to work through a bunch of records.
This type view is used in just about every E-Mail Program and many others and I’ve never seen it behave like this anywhere.
It would be a small change but I think it would improve that whole view by a lot! Would love for it to be considered :slight_smile:
Also it would be awesome if you could use the Split view on a regular Page or within a Record Page - Though I’d guess that would be a bigger change.
Oh and currently if you use groups in the Split view, the Group Header is ignored so the currently selected record is cut off/ hidden under the Group Header.
+1 to this request, a few of our users have complained about the jumping records!
plus one from me too - rolled split view out to the team and they noticed that immediately
+1 to this request, impacting the flow of users bi-weekly review meetings generating multiple complaints.
+1 I would like to second this as well.
I’m going to +1 this again, is the biggest complaint I get from users (which is great if this is the worst thing they’re worrying about!)
Edit: Nevermind, It looks like something was just stuck, everything works as it should again now.
So yea, great to have this feature now :slight_smile:
I think this has been resolved in a very recent update :tada:
Thanks Noloco team :slight_smile:
Hi @darragh, are you able to confirm this has been fully resolved as one of my users has raised it again. Thanks .
