2fa on business accounts
Hello, I’m having to enable this due to CyberEssentials requirements for financial services companies in the UK. Not ideal as its optional but better than nothing and will secure it enough to pass the audit, providing i keep an eye that the users don’t undo it :slight_smile:
I have a user and his staffmember who access my Noloco app on the same login, works fine so far for our purposes. But, if he sets up 2fa on his phone, then she tries to login it will ask her for the 2fa code. She doesn’t have it as she doesn’t have his phone?
Can 2 people use 1 login for 2fa on 2 different handsets?
Hey @garyGHL - sorry for the late reply, but I’m sure you figured out that this won’t be possible.
2FA is designed to double-authenticate the user as the correct user.
If you’re sharing a login, not only are you working against our usage terms, but you’re masking the actual user, which I would bet is against the CyberEssentials requirements in terms of reporting and actvity logging.
