Is there a setting I am missing for showing labels? The chart is set to 100% and full.
If not, is there a way to remove labels from the X axis?
Hi @Kieran - this is automatic, and built into the chart library we’re using.
You could use custom CSS to remove the labels completely if you would prefer but I wouldn’t recommend it.
On larger screens they labels should show up
