Hi there, the problem I am facing is that the text of the x-axis is so small that it is not possible to read it. Is there any possibility to set the font size? This also happened to me with bar charts
Hi @JCW - the only real solution is to make the text in the labels shorter
Otherwise we would need to make the bars in the chart very small
I understand. The issue is the text is not very long and even the shorter text is hard to read in both charts. In order to be able to really use the charts and be competitive with dashboards of other solutions it would be important to have better label readability via larger characters and eventually also by having some more options on the positioning of the labels… Having them horizontally and a bigger font size could already help for the bar charts. I know this might not be as easy as it sounds but the way they are currently setup the charts are really only usable for very simple use cases from my perspective.
