Filtering error in pivot tables
Hello,
I have a pivot table showing the amount of different items in various warehouses in the following link:
https://gintekik.noloco.co/depo/mevcutlar
I put a filter on values to see if anything goes below zero. The value of one item is -5 without the filters applied. When I put -1 to the max. value filter, I see the same item filtered but the new value is -15. I know the correct value is -5 and need help on this error.
Why i need this functionality: I need to filter and see which stocks are below zero in order to find out errors of warehouse managers.
Thanks in advance,
Arda.
Hi @ardaergin and thanks for sending us this question.
I’ve had a look at your data, and I think the correct value is -15
The top is your pivot table, and the bottom is the raw data in a table format, with the same filters applies (-1000 ↔ -1)
Hi Darragh,
The screenshot without filter:
The screenshot with filter:
As you can see I have 4 inputs for that stock and total SAYIM makes 5 for that stock. Breakdown to warehouses would be -5 in “BILECIK SRP” and 10 in “HÜKÜMET”. I’m trying to filter minus values but when I do it gives -15 in BILECIK SRP instead of -5.
I also put the raw data for that stock below in both screenshots.
Can you have a look again?
Thanks.
I’m also attaching the screenshot of the raw data with the warehouse name so you can better see:
stock_data
Would a max: -1 not filter out the 10 and 10 causing it to only be -5 and -10 as in my screenshot?
Oh i see now, it’s my bad, thanks very much.
