Lookup & Formula Fields Not Updating on Record Creation
I’m writing to ask about an issue we’ve been experiencing with lookup and formula fields not updating reliably in our app.
We’re using Noloco Tables as our data source. The issue: lookup fields and formula fields that reference lookups often do not recalculate when a new record is created or an existing record is updated via an action or integration. The fields only update after we manually re-open and save the affected record.
This is causing data integrity issues for us, as we rely on these computed fields for case management workflows.
A few specifics:
  • It affects both lookup fields and formulas that reference lookup values
  • The data in the source/related table is correct — it’s the computed field that isn’t refreshing
Is this a broader platform issue? Interested in understanding:
  1. Whether this is a known bug with a fix in progress
  2. Any reliable workaround in the meantime
  3. Whether there’s a way to force recalculation programmatically
We’ve had the same issue. But after they published a fix, I think it was last week, then we haven’t experienced it on new records.
