There’re still problems with the lookup field. It can be solved by recreating the lookup field, but it is so annoying, especially when the website has already gone live.
@darragh , if you are not aware yet, check out our tables. Not sure how to give you the table ID and column ID. This is quite fundamental, hope it can be fixed soon.
Hi @alancui , if you could DM us the link to the table and field which is having issues we an confirm whether it matches what we’re hoping to fix in the next week.
We’ve identified that it’s related to ONE_TO_ONE fields, or when an update is made to the reverse side of the field value
We’re hoping to have more progress in the coming week or two
This is still causing me some issues unfortunately. I have a scenario where I clone a record and all it’s linked records using Xano, but when the data is synced back into Noloco, I have a look-up which stubbornly refuses to work until I manually update any of the data in the record.
