Me and the users I work with struggle to click on lines on tables in Noloco. It seems that linked record fields, edit in line fields, and date fields, amongst others, create a large un-clickable area on table lines. Here’s an example of a user trying to find a clickable area:
For certain users, this is surmountable. But for many standard users, it becomes frustrating and a major roadblock.
I’m not sure about the exact solution, but it seems to me that one way to improve would be making more of the empty areas clickable to a line, and also having some sort of visual indicator that a user is hovering over an area that would navigate them to the record. (Like a highlight)
Another field type that is problematic is multi-select fields. If there is no value in the field, it is perfectly blank but a user cannot click that area to visit the record.
I think your solution is the best one for now, it’s just a lot of extra buttons to make with a large solution.
I run into this issue even without inline editing, but the inline editing definitely makes it worse. For examples of when it’s rough even without inline editing, blank multi-select fields are not clickable.
That’s too bad. I’m trying to implement the suggested solution using a button. I tried adding a record button - view details - this record. My intended use is to navigate into the detail page of the row’s record. I’m likely doing something wrong here.
